ok no problem i have searched it on my own and got with the help of www.ranawaseem.com thank you Rana Waseem sab ,that if the number in denominator is greater than 98 drift is ok ,but i have doubt because an engineer told me that it should be greater than 400.any one would like to comment please?
Also sir you told me after this i posted it here, thank you for guidance and response,i have analysed that model it is interesting !!!i increased the size of columns to 18x18 but one of the mumty column is still overstressed even there is very minute load on mumty ,on the lower floors same column has reinforcement ratio less than 2%,what is the reason ?it is basment+4 including mumty.zone three abotabad
interesting and most common...
you have more reinforcement at upper columns because less axial force and more moment....so more eccentricity...more reinforcement
while columns below have less moment and more axial force...as compared with the top columns meaning less eccentricity so less reinforcement
from where more moment is coming on top columns?
solve a portal frame 2 bay by 3 stories!
kindly check the values for a model i have analysed in etabs and briefly tell how we check that our drift values are ok or not? a snap of the drift values table is attached
http://www.sepakistan.com/topic/109-building-drifts-in-etabs/
For a refresher, if you have seen it before.
  • 6 years later...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
