Difference Between Column And Shear Wall
asadishaq
When is the right time to consider designing a shear wall instead of a column?Can you please guide me on some code provisions regarding this matter.
what do you prefer, design a column with a cross section of 42"x10" or a structural wall of the same dimension? Both will be subject to gravity and lateral loads.
I think it depends on the lateral load resisting system, which depends on seismic zone, and which also depends on the arrangment and size of remaining vertical members. Ductility demands a specially reinforced boundary regions in shear walls, and it must of that much stiffness to attract that much forces, which will depend on the size,  and detailing of others members of lateral load resisting system.
columns are for gravity loads , whereas shear walls are basically to make  structure resistant towards lateral forces....you will see that when you are working in low seismic zone there will be mostly no need of shear walls ...
sir zeeshan make me correct if i am wrong...
Columns also take part in resistance od lateral loads; they do so  by rotation of beam column joint; and due to confinement of column core, confinement beam-column joint and by accounting for extra shear and bending requirement in plastic range. In moment-resisting-frame structures, they are only source; but in dual system, or a system consisting of large number of shear walls, their effect is less.
in the case 42"x10" column size ?coulumn must have some proportion in both dimensions it is too stiff in one direction and too weak in other.before proposing a shear wall, designer must consult with the contractor and ask the proof of his competency for constructing a shear wall especially in Pakistan.shear wall is better option if could be constructed precisely
