Salam Everyone!
We are a steadily growing community now. I thought about posting forum rules which are always a good idea to keep new members streamlined to forum decorum. Please do share your thoughts on any modifications to the rules.
  1. Read the forums rules and guidelines before posting for the first time.
  2. Please use first names to address people & don't address anyone with a prefix. Calling someone Sir is prohibited.
  3. Search the other posts to see if your topic is already covered.
  4. Use a meaningful title for your thread and topic tag.
  5. Do not use a forum to promote your product, service or business.
  6. Be civil. Personal differences should be handled through email or IM and not through posts displayed to everyone.
  7. Stay on topic.
  8. Ignore spammers, respond to them personally and not through the board, or report them.
  9. Use plain text over HTML if you want your post to be readable by everyone.
  10. In order to be understood by most people, use correct spelling, grammar and avoid slang unless you know the word or phrase will be understood by other members.
  11. Do not double post (post the same message twice in one thread) or cross post (place the same message across several forums).
  12. Act in a give and take manner; help others as often as or more than you ask for help.
  13. Do not use all caps or SHOUT in your posts. In addition, one exclamation point is enough.
  14. When replying to a post, do not quote more from the previous post than you have to.
  15. Do not post new problems on someone else's thread and interrupt a topic of discussion.
  16. Do not use someone else’s thread for a private conversation.
  17. SEFP prohibits warez, cracks or illegal downloading of software and similar topics.
  18. Watch your sense of humor, posts may be read by people from a variety of backgrounds and ages.
  19. Do not use a huge and annoying signature, a modest signature is fine, moderators may remove large ones anyway.
  20. Do not post any information that you want private. Posts should not contain personal, identifiable information or content embarrassing to others.
  21. Do not post content that violates a copyright.
  22. Do not post ”empty” or useless responses, such as just ”lol” or ”cool.” Only post responses when you have something to contribute.
  23. Write concisely and do not ramble.
  24. Do not use words like ”urgent” or ”important” in your subject line, be patient.
  25. Post stuff on the forum rather than sharing through other means(email etc). If your desired attachment type is not supported, inform the moderators so that changes to board can be made. You can always zip files and upload them.
  26. Do not chastise newbies.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
