Column Failure!!!
salam
Dear fellows
we have two concrete columns C1 and C2 with heights x and y .C1 is on the land and C2 is submerged in water.it is a test so there is no steel in the columns.we need to find the x and y on which these two columns will fail by crushing at the base.
salam
Dear fellows
I remember this was asked in Nust Masters Exam and is a pretty typical question around. Here is a possibility:
1) C1: Equate weight of column(in terms of height) to compressive stress and find h.
2) C2: Here there are two stresses. Lateral stress of water and compressive stress. Both stresses can be expressed in terms of height and simplified? I am thinking about how would we relate the two expression without complicating things but cant get up my mind ? anyone else can suggest something ?
You can use those elastic-2D stress-strain relationships to solve this problem. You will need to assume the values of crushing strain, cross-sectional area and elastic modulii of both columns. You will assume same values so that you can compare the effect of confining stress.
following relation will be use: strain y = 1/E[stress (y) - Poisson's ratio . stress (x)]
 For the case without confining stress,  stress(x) is zero, and for the other case, it is hydro-static pressure at the base of column, which will also be expressed in terms of height of column.
As it is mentioned in earlier comment, you will express stress(y) as function of cross-sectional area and height of column.
crushing strain will need to be substituted for strain(y).
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
