Expansion Joint
abdulqadeer29
i have attached column layout plan of a 20 storey building,i am dithering about its expansion joint, whether to provide it or not. not found any code evidence yet. some books recommend   expansion joint after every 150-200 ft. and some even allow up to 300 feet without any expansion joint.
kindly suggest some authenticated source , on the basis of that i can decide.
PLAN.pdf
sir, issue is not about location,
 it is more about whether we should provide it or not.??
according to some views , it is recommended that we can increase temperature and shrinkage reinforcement and avoid expansion joint.
i am still at the same point, should i go for ????
I do not have any published-source in mind that can be referred. As far as I know, expansion joint are needed for two reasons: to arrest temperature/shrinkage cracks,  and to fend-off unwanted/complicated behavior against seismic/wind actions. As you have mentioned in your post, different authors have recommended different ways to deal with temperature/shrinkage stresses according to their experience.
In this problem you have to decide why are you thinking of providing expansion joints. Is it for temperature/shrinkage , or seismic/wind, or for both.
I know two factors that needs to be considered while providing expansion joints for seismic actions:to avoid torsional behavior due to building shape/structural system, or to avoid the complex behavior that the structure may have to deal with in the case of building experiencing earthquake of different magnitudes at its different areas, which can happen if the building/structure is spread over large area (bridges, stadiums etc).
our main problem is regarding temperature and shrinkage.
in case of seismic, this building behave well due to presence of main two heavy cores in resisting against seismic forces without expansion joint.
i am attaching complete plans just to give you an idea of typical floor plans.
now can i avoid expansion joint by increasing temperature and shrinkage reinforcement.??
4th. to 13th.Floor Plan.pdf
Basement-1 to Basement-3.pdf
Lower Ground to 3rd Floor Plan.pdf
Abdul Qadeer: you will, most probably, provide the reinforcement ( flexural reinforcement in both directions) which will be  more than what is required for the temp-shrink. So, I don't think its a valid question.
Will temperature differentials have an effect on  serviceability in spite of that increased reinforcement? I am not sure.
AQ, you should read Joints in Concrete Construction Reported by ACI Committee 224 to get answers for most of your questions.
Here is the abstract of the document:
This report reviews the state of the art in design, construction, and maintenance
of joints in concrete structures subjected to a wide variety of use and
environmental conditions. In some cases, the option of eliminating joints is
considered. Aspects of various joint sealant materials and jointing techniques
are discussed. The reader is referred to ACI 504R for a more comprehensive
treatment of sealant materials, and to ACI 224R for a broad
discussion of the causes and control of cracking in concrete construction.
Chapters in the report focus on various types of structures and structural
elements with unique characteristics: buildings, bridges, slabs-on-grade,
tunnel linings, canal linings, precast concrete pipe, liquid-retaining structures,
walls, and mass concrete.
I also recommend having a look at this link.
