Assalam o alekum
Providing bracings in the building greatly reduces lateral diaplacements can we provide concrete bracings? or what property we should assign to brace element a beam or a column?,I modelled a concrete brace element in ETABS but Etabs donot design it for axial compression or tension
Concrete is poor in tension and effectively in a RCC brace, all tension would be taken by re-bars. However, concrete bracing can be designed, but hard to pour, construct and place and may not be feasible where tension forces are huge.
Regarding ETABS comment, you can take ETABS forces and design it manually. Method of Strain Compatibility would be of choice is such a case. MacGregor has an example on that.
