Beam Slab Joint
saleem khan
AOA:i want to connect my slab flush with the underside of beam in etabs but there is no option  insertion point of shell  to frame objects in etabs or if it is i have not found yet .cardinal points apply only to frame objects.
by the way why u like to connect slab to the underside of beams? beams are modelled as line elements and slab as area element....to connect it that way you need to model 3d beam elements not 2d elements...also make sure you understand the basics of FEM for connecting different types of elements to each other
Rana has made a good point.
You should be careful about what you want to include in your analysis model and what you want to exclude.
Without good understanding of meshing and a fervor to model everything would result in highly erroneous models.
Also excluding important items like staircases and ramps, would change the response of your structure under seismic loads.
There is no rule but thought should be given before setting up the analytical model.
Like Rumi said, the art of knowing is knowing what to ignore.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
