Relative Stiffness Of Beams And Columns
Hasan Tariq
If we have 2D single frame .What the etab consider the joint of beam and column .does the beam behave as a simply supported or fixed ?
I am asking this question becasue while designing the houses we have bearing wall structure in which we do manual calculation .but on the beam i used to get confuse how to calculate the moent on them either consider it simply supported or what .Your kind advise is required
It behaves in between simply supported and fixed...depending upon the relative stiffness of beam and column..If column stifness is much more, then the beam would behave as fixed (near to fixed) and pin if column stiffness is very less...
Thanks sir :)
can we have a ratio to compare so to have some direction to follow like how much times the stifness of the column is to consider the beam near to fixed or fixed .?
there is no ratio to compare it.
  • 7 months later...
in case of fixed ended beam, there is no rotation at supports. but when a beam is modeled with its supports on column, then there is rotation at ends of beam because of bending of columns. So this support is not fixed. And not simply supported because beam ends are not fully allowed to rotate as in case if beam is resting on masonry walls. If beam is continue then for approximation u can use moment coefficient method. Other wise u can use wl2/11 or wl2/12 for end and midspan moments as conservative design. You can also model this frame in etabs.
  • 2 years later...
On 3/15/2015 at 11:55 PM, kHURRAM ALI said:
use alignment charts to compare stiffness of beam and column with the help of K value if K value is near to 0.5 it is consider to be fix or if it is 1 then it is near to pin
Can i have the link for Alignment charts? where can i find alignment charts? Are these available at Design of concrete structure by H. Nilson?
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
