Slab On Grade
Hasan Tariq
Slab on grade is  a foundation type and the use of the term varies from region to region. I have seen them to be provided normally in Industrial Buildings as floors. They are designed for storage + machinery operating loads  like fork lifter etc. Frost Heave is a concern for most slabs on grade.
In Pakistan, I have seen some firms providing reinforced slab panels above grade and calling it Slab on Grade. That is a reinforced slab panel not slab on grade. To be classified as slab on grade, the slab panel should be acting as the sole foundation. Thats what I would say. Other may disagree.
JAZAKALLAH :)
Sir If slab pannel would be acting as a sole foundation ,thn do this slab behave as a raft .
In my case SOG is provided at the floor level and  the foundation @depth of 8.5' down from FFL seperately.
Do SOG is only be recommended for storage and machine operating areas ? .
is sog steel connect with plinth beam or not? i observe that when we connect with plinth beam vibration is  transfer through col to first floor
It should be connected. I have seen consultants not connecting it too. It comes again to how the consultants define SOG rather that what an actual SOG is.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
