Material Property Data
shahram555
You have not mentioned units.
Anyway Weight per unit volume of concrete is: 24 kN/m³ which is 2.4E-05 mPa or (N/mm²).
To get mass per unit volume divide the weight by 9.82; we get: 2.450E-09 mPA.
It looks like above numbers in your post are wrong due to wrong units.
Weight of a material is related to the its mass through the relation
                 W = m g --------- (1)
Dividing both sides of above equation (1) by 'g' , the relation changes to
                m = W/g --------- (2)
where
  W   is the weight of the material
  m   is mass of the material
  g    is the acceleration due to gravity
Equation (2) gives the mass of a material in terms of weight of the material. Simply speaking, mass of of a material is obtained by dividing its the weight by g (acceleration due to gravity).
This relation holds good even if 'weight' is replaced by "weight per unit volume", AND, the 'mass' by "mass per unit volume".
You have to use consistent units in above equations.
Now coming to your question;
'Analysis Property Data' is related to the properties of the structural material you are using for the frame elements (beams, columns, etc).
For example, if you are modeling your structure as a Concrete Frame, 'Analysis Property Data' is related to the structural properties of Reinforce Concrete (denoted by "CONC", in ETABS).
In this case, using "lb-ft" units in ETABS, 'weight per unit volume' value should be about 150 lb/ft^3 (= normally used unit weight or density of reinforced concrete), with  "mass per unit volume' being 150/g = 150 /32.2 = 4.658. (32.2 is the value of 'g' when the unit weight is in 'lb-ft' units).
Select the Units of your choice in ETABS, that you normally use in manual calculations, and then observe the corresponding value of 'weight per unit volume' for reinforced concrete (CONC)  and structural Steel (STEEL) in 'Analysis Property Data' .
Keeping above discussion in view, and the values indicated by ETABS should hopefully make you clear regarding wherefrom these numbers have come.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
