Properties Of Tor Bars & Deformed Bars
Ghulam Abbas Gazer
Respected All
             Define the properties of Tor bar & deformed bar according to there usage in structural member.
             I noted normally consultant suggest tor bar for beams & slab reinforcement & deformed bars for stirrups & longitudinal bars of columns what,s philosophy behind this factor.in case of equal grade of both type of steel what will be select.is it right that tor bar is better in tension than deformed bars.
i checked in drawings that longitudinal bars of columns up to 20 mm dia normally used tor steel & above 20 mm dia deformed bars are used.
Regard.
Ghulam Abbas
