How To Load A Beam Near Bottom?
Dear members
salam http://www.sepakistan.com/public/style_emoticons/#EMO_DIR#/smile.png
in the ACI 11.1.3.1commentary
Fig.R11.1.3.1(http://www.sepakistan.com/public/style_emoticons/#EMO_DIR#/cool.png it is mentioned that if a beam is loaded near bottom critical shear should be considered at the face of support and not at a distance d from the face of support as in the case of beam loaded at the top.same case is when supporting member is in tension R11.1.3.1(e)
relevant commentary and figures are at the link plz check
http://wiki-edupunk.blogspot.com/2012/08/aci-commentary-r11131.html
1.why is it so?why critical shear at the face of support?
2.how can practically a beam is loaded near bottom?
Thanking you in anticipation for your kindness and guidance
Beam can be loaded at bottom, imagination respects no boundaries.One condition is of inverted T-beam.
Why is critical section for shear at a distance 'd' from the face of support for other cases? if you can answer it than you can answer your own question.
It is because shear crack develops at least at a distance d from support in other cases but it is not the case in this particular condition.
Take it the other way, if your load creates compression in the support and its a not in a disturbed region, take critical shear at distance d from the support.
