Etabs Modeling: Load Transfer Error
Haneen Bdoor
It is normal. and loss of accuracy happens due to many reasons. For example, areas overlapping etc. Unless you see ***WARNING*** Structural is ill conditioned in last analysis run log, keep going. But just check how can you improve the model.
Check if you meshed membranes or applied modifiers to them. Things like that generate these type of errors
Program ETABS Version 9.6.0.0                                  File:project.LOG
B E G I N   A N A L Y S I S                                2014/11/05  11:54:19
MAXIMUM MEMORY BLOCK SIZE (BYTES)         =      64.000 MB
E L E M E N T   F O R M A T I O N                                      11:54:19
NUMBER OF JOINT  ELEMENTS FORMED          =        1832
NUMBER OF SPRING ELEMENTS FORMED          =           0
NUMBER OF FRAME  ELEMENTS FORMED          =       41832
NUMBER OF SHELL  ELEMENTS FORMED          =       18647
NUMBER OF CONSTRAINTS FORMED              =          14
REDUCTION OF CONSTRAINTS AND RESTRAINTS:
NUMBER OF
CONSTRAINT MASTER DOF BEFORE REDUCTION  =          42
COUPLED CONSTRAINT/RESTRAINT MASTER DOF =           0
CONSTRAINT MASTER DOF AFTER REDUCTION   =          42
E Q U A T I O N   S O L U T I O N                                      12:13:18
TOTAL NUMBER OF EQUILIBRIUM EQUATIONS     =       64098
APPROXIMATE "EFFECTIVE" BAND WIDTH        =         766
NUMBER OF EQUATION STORAGE BLOCKS         =           6
MAXIMUM BLOCK SIZE (8-BYTE TERMS)         =     8388608
SIZE OF STIFFNESS FILE(S) (BYTES)         =     384.343 MB
NUMBER OF EQUATIONS TO SOLVE              =       64098
NUMBER OF STATIC LOAD CASES               =           3
NUMBER OF ACCELERATION LOADS              =           6
NUMBER OF NONLINEAR DEFORMATION LOADS     =           0
* * * W A R N I N G * * *
THE SOLUTION LOST  7.8 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    3354
LOCATED AT X =   66.600000, Y =   30.650000, Z =   18.400000,
STIFFNESS MATRIX DIAGONAL VALUE =  5.0055E+15
THE SOLUTION LOST  7.6 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    3353
LOCATED AT X =   66.600000, Y =   27.200000, Z =   18.400000,
THE SOLUTION LOST  6.7 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    3314
LOCATED AT X =   71.600000, Y =   30.650000, Z =   18.400000,
STIFFNESS MATRIX DIAGONAL VALUE =  3.9402E+14
THE SOLUTION LOST  7.8 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    6844
LOCATED AT X =   66.600000, Y =   30.650000, Z =   15.290000,
STIFFNESS MATRIX DIAGONAL VALUE =  1.0011E+16
THE SOLUTION LOST  6.7 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    6804
LOCATED AT X =   71.600000, Y =   30.650000, Z =   15.290000,
STIFFNESS MATRIX DIAGONAL VALUE =  7.8803E+14
THE SOLUTION LOST  7.6 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    6843
LOCATED AT X =   66.600000, Y =   27.200000, Z =   15.290000,
THE SOLUTION LOST  7.8 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   10334
LOCATED AT X =   66.600000, Y =   30.650000, Z =   12.180000,
THE SOLUTION LOST  6.7 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   10294
LOCATED AT X =   71.600000, Y =   30.650000, Z =   12.180000,
THE SOLUTION LOST  7.6 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   10333
LOCATED AT X =   66.600000, Y =   27.200000, Z =   12.180000,
THE SOLUTION LOST  7.8 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   13824
LOCATED AT X =   66.600000, Y =   30.650000, Z =    9.070000,
THE SOLUTION LOST  6.7 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   13784
LOCATED AT X =   71.600000, Y =   30.650000, Z =    9.070000,
THE SOLUTION LOST  7.6 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   13823
LOCATED AT X =   66.600000, Y =   27.200000, Z =    9.070000,
THE SOLUTION LOST  7.8 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   17314
LOCATED AT X =   66.600000, Y =   30.650000, Z =    5.960000,
THE SOLUTION LOST  6.7 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   17274
LOCATED AT X =   71.600000, Y =   30.650000, Z =    5.960000,
THE SOLUTION LOST  7.6 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   17313
LOCATED AT X =   66.600000, Y =   27.200000, Z =    5.960000,
THE SOLUTION LOST  8.7 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   17535
LOCATED AT X =   66.603571, Y =   27.200001, Z =    2.850000,
STIFFNESS MATRIX DIAGONAL VALUE =  8.8576E+15
THE SOLUTION LOST  7.6 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   18761
LOCATED AT X =   66.603571, Y =   30.650000, Z =    2.850000,
THE SOLUTION LOST  7.7 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   18758
LOCATED AT X =   71.591667, Y =   30.650000, Z =    2.850000,
STIFFNESS MATRIX DIAGONAL VALUE =  6.9725E+14
THE SOLUTION LOST  7.1 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    3383
LOCATED AT X =   26.700000, Y =   12.350000, Z =   18.400000,
STIFFNESS MATRIX DIAGONAL VALUE =  1.4831E+15
THE SOLUTION LOST 10.4 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    3360
LOCATED AT X =   31.950000, Y =   12.350000, Z =   18.400000,
STIFFNESS MATRIX DIAGONAL VALUE =  1.5539E+17
THE SOLUTION LOST  7.1 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    6873
LOCATED AT X =   26.700000, Y =   12.350000, Z =   15.290000,
STIFFNESS MATRIX DIAGONAL VALUE =  2.9662E+15
THE SOLUTION LOST 10.5 DIGITS OF ACCURACY FOR DOF UZ OF JOINT    6850
LOCATED AT X =   31.950000, Y =   12.350000, Z =   15.290000,
STIFFNESS MATRIX DIAGONAL VALUE =  3.1078E+17
THE SOLUTION LOST  7.1 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   10363
LOCATED AT X =   26.700000, Y =   12.350000, Z =   12.180000,
THE SOLUTION LOST 10.5 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   10340
LOCATED AT X =   31.950000, Y =   12.350000, Z =   12.180000,
THE SOLUTION LOST  7.1 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   13853
LOCATED AT X =   26.700000, Y =   12.350000, Z =    9.070000,
THE SOLUTION LOST 10.5 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   13830
LOCATED AT X =   31.950000, Y =   12.350000, Z =    9.070000,
THE SOLUTION LOST  7.1 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   17343
LOCATED AT X =   26.700000, Y =   12.350000, Z =    5.960000,
THE SOLUTION LOST 10.5 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   17320
LOCATED AT X =   31.950000, Y =   12.350000, Z =    5.960000,
THE SOLUTION LOST  9.2 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   19220
LOCATED AT X =   31.948864, Y =   12.350000, Z =    2.850000,
STIFFNESS MATRIX DIAGONAL VALUE =  2.7497E+17
THE SOLUTION LOST  8.4 DIGITS OF ACCURACY FOR DOF UZ OF JOINT   20833
LOCATED AT X =   26.700000, Y =   12.350000, Z =    2.850000,
STIFFNESS MATRIX DIAGONAL VALUE =  2.6245E+15
E I G E N   A N A L Y S I S                                            12:16:50
NUMBER OF STIFFNESS DEGREES OF FREEDOM    =       64098
NUMBER OF MASS DEGREES OF FREEDOM         =         768
NUMBER OF EIGEN MODES SOUGHT              =          12
NUMBER OF RESIDUAL-MASS MODES SOUGHT      =           0
NUMBER OF SUBSPACE VECTORS USED           =          16
RELATIVE CONVERGENCE TOLERANCE            =    1.00E-07
FREQUENCY SHIFT  (CENTER) (CYC/TIME)      =     .000000
FREQUENCY CUTOFF (RADIUS) (CYC/TIME)      =     .000000
NUMBER OF EIGEN MODES FOUND               =          12
NUMBER OF ITERATIONS PERFORMED            =           7
J O I N T   O U T P U T                                                12:17:06
G L O B A L   F O R C E   B A L A N C E   R E L A T I V E   E R R O R S
PERCENT FORCE AND MOMENT ERROR AT THE ORIGIN, IN GLOBAL COORDINATES
LOAD          FX          FY          FZ          MX          MY          MZ
DEAD        0.030371    0.001515    0.000174    8.65E-05    0.000208    0.025084
LIVE        0.026467    0.001502    0.000175    8.65E-05    0.000208    0.022007
TRIBUTAR    0.026467    0.001502    0.000175    8.65E-05    0.000208    0.022007
MODE          FX          FY          FZ          MX          MY          MZ
1    1.108111    0.063451    0.006786    0.004604    0.011137    0.998196
2    1.733451    0.019346    0.002882    0.001665    0.003900    1.410044
3    0.036971    0.074303    0.000750    0.000315    0.000820    0.038522
4    0.032950    0.128142    0.000817    0.000249    0.000650    0.024915
5    1.200286    0.006370    0.001108    0.000556    0.001491    0.951965
6    0.019499    0.059370    0.000752    0.000211    0.000549    0.013601
7    1.641052    0.072867    0.001209    0.000824    0.001982    1.505039
8    0.864114    0.006629    0.000721    0.000639    0.001450    1.043113
9    0.019391    0.130645    5.60E-05    8.37E-07    4.65E-05    0.014759
10    0.462425    0.006673    0.000215    5.78E-05    0.000295    0.376063
11    0.022310    0.034721    0.000437    7.26E-05    0.000490    0.023589
12    0.007123    0.012936    0.000308    6.10E-05    0.000248    0.005297
E L E M E N T   J O I N T - F O R C E   O U T P U T                    12:17:09
NUMBER OF JOINT  ELEMENTS SAVED           =        1832
NUMBER OF FRAME  ELEMENTS SAVED           =       41832
NUMBER OF SHELL  ELEMENTS SAVED           =       18647
E L E M E N T   O U T P U T                                            12:17:20
A N A L Y S I S   C O M P L E T E                          2014/11/05  12:17:20
So
C E N T E R S   O F   R I G I D I T Y                                  12:17:43
Your warning messages are loss of accuracy. Nothing critical as you don't have any stability warnings.
Normally, what you can do is that wherever you have a **Warning** message, you can go to the joint of interest; for information below, error is for UZ at Joint 3354, and zoom in to the Joint for visual inspection to see if everything looks good.
I haven't used ETABS in years, but, I remember that when I used to get such messages, I would check the joints, zoom in and would always find some kind of misalignment of slab with beam. The slab or beam would not align and there would be some gap or misalignment. You can spot it visually if you zoom there. You can then redraw the slab or refine your mesh there. Give it a try and post any pictures of mismatches that you find.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
