Framing System
dccar
WHAT WOULD BE THE PROPER FRAMING SYSTEM FOR A POST TENSIONED FLOOR SLAB SYSTEM WHICH WILL BE SUPPORTED BY STRUCTURAL WALLS AND COLUMNS?
PLEASE ENLIGHTEN ME WHETHER TO USE BEARING WALL, BUILDING FRAME SYSTEM, MOMENT RESISTING FRAME OR DUAL SYSTEM. I AM CONFUSED WITH THE TERM "COMPLETE VERTICAL LOAD CARRYING SPACE FRAME" AND "WITHOUT COMPLETE VERTICAL LOAD CARRYING SPACE FRAME".
THANK YOU VERY MUCH.
It will depend on your architectural constraints and seismic zone.  All these systems have different ductility ratios. You need to choose accordingly.
A lateral load system may not have any columns and beams, and in that system all lateral, as well as gravity forces, are resisted by shear walls. Such system is without vertical load carrying space frame.
  • 9 months later...
The type of structural framing system depend on many factors such as;
energy dissipation characteristics
interaction of rigid frame with shear walls and compatibility of deformations of slab and walls
loss of stiffness and amount of cracking, softening, yielding
self weight, concentration of shear forces, torsional resistance
coupling of gravity and lateral loads
etc
It would be unwise to say anything without checking architectural features and constraints and the behavior/scope of structural design
I want simplicity please!!!! what are you saying ....
If a building has corewalls and columns+ beams  (MRF system) then I may consider he building acting as building frame system
(depending on shear walls ) and using R related . and we may also consider it as dual system and designing the frames and shear walls to resist the base shear. This what I know !!!
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
