Defining Mass Sources
EngrJunaid
Hello everybody...
I have 2, 3 querries and hope you people will help me out...
1) Defining MASS SOURCE : there are three option there in Mass source (a) Element Self mass ( B) Additional Masses © Specified Load Pattrens
I am confuse that in which situation which condition i will use.
2) After Running Check Model option i got Areas are too close and Frame overlap warnings
1) Mass source is related to your seismic mass. You can specify "from loads" and assign all load cases that refer to dead weight with a factor of 1 and live load cases as per code with the appropriate factor based on governing condition. It is always a good idea to confirm the total seismic weight/mass from Etabs to your manual calculation. Please see links below that discuss this aspect.
http://www.sepakistan.com/topic/1310-checking-analysis-result/
http://www.sepakistan.com/topic/191-use-of-mass-source-command-in-etabs/
2) Post your analysis log.
