Simply Supported Deep Beam
danny740
Hi,
I have a problem with  a simply supported deep beam which has a uniformly distributed load. The beam is simply supported at both ends but I have to consider the results for the following 3 scenarios
- where the support is at the bottom of each end of the beam
- where the support is at the mid point at each end of the beam
- where support is at top of each end of the beam
I have run this using FEA and I'm finding significantly different deflections and stresses when the beam is supported at the midpoint at its end and the other two scenarios...can anyone explain the exact reasoning for this?
Sincere thanks
Daniel
Hi Rana,
Yes any advice to my issue?!
I have the beam pinned at one end with a roller at the other end. I'm seeing a difference of ~40% in the deflection of the beam when the support is at the mid height to the when the support is at the bottom/top end
Kind Regards
Danny
What FEA software are you using?
How are you checking FEA results manually? Calculate flexural plus shear deflection manually and compare with FEA. (Not just flexural)
flexural defl = 5wl^4/384EI
shear defl = 0.15wl²/GA
Regarding supports;
If you apply supports at top or bottom of beam, results will be same but with opposite sign. Tensile, compressive and shear stresses will be reversed.
Middle supports will produce linear distribution of flexural longitudinal stresses at the center of the beam. You could use this to compare FEA results with hand calculations, and you will not find much difference. Then use this as benchmark to compare the results of other supports.
Thanks for response Rana,
Its a deep beam so using Timoshenko formula for deflection (5/384)*(qL^4/EI) + (alpha*q*L^2/8AG). I got this formula from  his book 'strength of materials'. To calculate the bending stress I was using the standard formula My/I....with the moment calculate as standard for a simply supported beam...not sure if this is correct so if you have any advice here it would be appreciated?
I'm using LUSAS. I found that when I applied the support at mid height of beam that I got around 50% less deflection than when I applied the support at top/bottom of beam. Also my deflections calculated by hand more closely matched when beam supported at top/bottom which is contrary to what you were saying I should find??
Well I used LUSAS too. But dont worry, the formula you have written above is sum of shear and flexural deformation. I just wrote it separately. No worries.
Well I am not sure why the deflection in your case matched well with top/bottom supports. But just make your report and write your results. At the end the instructor wants to see how well you can compare FEA results.
Rana,
Would you please be able to tell me how to manually calculate the bending and shear stresses in a deep beam? They are different to a normal thin beam i believe. I can't find anything on it in Timoshenko book
Any guidance is much appreciated
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
