Free Concrete Design Publications From Pca
EngrUzair
Assalam-o-alaikum!
You can get soft copies (PDF files) of the following two publications, FREE OF COST from PCA website:
1. PCA Notes on ACI 318-11
    (Link: http://members.cement.org/EBiz55/ProductCatalog/Product.aspx?ID=2137)
2. 'Simplified Design of Reinforced Concrete Buildings', based on ACI 318-11 and IBC 2009  by Kamara & Novak 2013
   (Link: http://members.cement.org/EBiz55/ProductCatalog/Product.aspx?ID=2246)
You will need to go through following steps:
a. login at PCA website, after creating a free membership account using your valid email address.
b. Search and add the above publications to your 'cart'.
c. Both pdf files are password protected. The passwords will however be displayed in your purchase list, after you add these downloadable items to the 'cart'. Note the passwords, before 'Check out' & confirming your order.
d. 'Update' and 'Complete/Confirm' the order. A confirmation email, with a web link, will be sent to your email address.
e. Go to your email. Click on or open the link in separate window.
f. Login, and download the files from 'Available Downloads' list.
Enjoy!
Assalam-o-alaikum!
A little addition.
As far as I know, the passwords for the above mentioned two files are the same for all. These are given below:
   (Password: '2013PCAEB712')
   (Password: '2011PCAEB204')
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
