Footings, Wind And Earthquake!!!
Every load experienced by superstructure has to be transferred to foundation, where else it can go?
One of the important factor in earthquake cases is the soiltype : you cannot put isolated foundation on the soil susceptible to liquefaction.
Having said that, Earthquake/wind loads may not have same influence on every structure, depends on type of structure and also construction material. Footing dimensions under the structure with huge gravity loads have lesser effect due to earthquake or wind loads: if soil is not susceptible to liquefaction.
in my experience with normal gravity loads..here in saudi arabia! even zone 2A (UBC Seismic Zone) makes footing size approx more than double of the original (gravity loads). This is because you need self weight to resist uplift for wind pressure and earthquake. Reinforcement is also changed and often you have to do non linear uplift analysis for these cases.
Footings are ofcouse desgined for earthquake and wind reactions to support structures. Otherwise the building may overturn due to uplift, soil liquefaction and other things.
