How To Apply For A Job?
Tstruct
Assalam u alaikum,
I am a fresh civil engg. graduate and looking for a job. Do I have to enclose my CV and cover letter into an envelope send it to every employer? or just CV is required? If cover letter is necessary, then what should be the matter of this letter?
W/Assalam!
Taimur! You may apply for employment in two ways:
1. Where an advertisement has been given for the job
   Method of applying for the job, as well as what information is to be provided with the job application, in normally provided in the advertisement. So, in this case, you should follow the procedure specified in the advertisement.
2. When you want to apply on your own (without any advertisement)
    It would be better to apply with your CV, supported by photocopies of your educational degree (Matric onwards), and any experience or special skills certificates (e.g., computer , CAD, or civil engineering related software courses etc.).
As regards the cover letter, do a search on the internet. you will certainly find some good tips (may be some good book too) regarding how to write a good  CV/resume, and what should be included in a cover letter.
Best of luck.
Salam
hunting for job!!!
it is easy and advantages to join some consultant or contractor as internee/trainee engineer, this will give you a good look into the professional life. You will be able to decide which way to go according to your interest and develop some professional contacts.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
