A.A! hope all of the members are fine. actually i want some guideline regarding FYP. i want to have FYP related to disaster management in building.
  • first of all i want guidance what type of topic i can select? seismic, landslides, floods all are disasters should i go for only seismic considerations? if yes which area i should select?
  • second thing is is seismic design i should do or seismic retrofitting?
i'm student of Bsc Arch. engg , kindly share some topics too on which i can work according to my level that you think will have some scope in Pakistan.
Another query i forgot to mention that can blast be considered in disaster management, (man made disaster)? i mean to say can it give a good topic for FYP and have scope in Pakistan? Department's chairman require projects that will have some market value because these projects will be displayed and exhibited to different personnels from renowned construction firms.
Assalam-o-alaukum!
In engineering institutions, normally all the teachers having PhD degrees are busy in carrying out research in their respective areas of expertise, because of their service requirements. For this purpose, most of them will have new ideas and topics to carry research on.
Accordingly, IMO, the best and the easiest way to select a topic for your FYP, is to contact your teachers (especially those having PhD degrees), and get their views about what kind of topic they propose to work on. From the ideas, obtained in this way from various teachers, you may select a topic (you might be interested in) to start preliminary working on and to adopt it later for your FYP after polishing the topic in various respects.
Mahnoor,
Here are my two cents:
Final Year Project is an important milestone in your educational career. A lot of students treat them as a degree requirement but you can get a lot more out of a final year project . All it would take is a little research before you dip in a topic.
If you plan to do graduate studies, then, make a list of engineering universities than you plan to apply. Visit their Civil/ Structural Department page. You will find links to webpages about faculty. Go there, and look at what area of research different professors are actively into. Each professor works on something different. Review a few universities and a few profs. Get their research interest and do something similar in undergrad that once completed can help you get a funding to that university based on your undergrad project or research. If you don't to pursue graduate studies then frankly it doesn't matter. You can pick seismic because that has been the hot topic ever since the 2005 earthquake. No one apparently cares about floods. This answers your first question.
Regarding second question, retrofitting is superior to seismic design and would add value to your resume.
Salam
FYP topic should be of your interest. and like uzair mentioned check with your teachers which topics they are working in.At ungergrade level some work which is of practical knowledge is better than just theoretical/software based project. some FYP topics:-
1) model some real time/scaled down structural element beam/column/frame test it and than retrofit the same and check its performance again.
2)you may support this practical work with simulation but this will be over kill at this level
3)blast loading effects or progressive collapse is good for the present situation and you can specify safe building line for different blast loadings
4)work on local materials like aggregates/cements and other additives,cast cylinders/cubes check different properties
5)check performance of recycled aggregates against seismic loadings/blast loadings
6)target poor construction practices which is very serious issue in pakistan and support your view with experimental work suggest how constrcution practices can be improved
7)delay in completion of projects work on the locally delayed projects as case study
8)compare repairability/retrofitting of different structural systems with respect to time/cost/economy
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
