Ug Fyp On Seismic Retrofit Software
MMohsinlive
Hello dear fellow Engineers,
I would be thankful to all those Masters and pHD's on this site if U can Recommend me doing fyp on Siesmic retrofit of Existing Brick Masonry Structures. Am planning to build a user friendly software to determine the most economical retrofit and its cost.
Any suggestion would be really helpful regarding it's feasibility.
Assalam-o-alaikum!
1. Before you can develop some software, you must have following skills, at least:
a. know-how of programming in the computer language or environment (e.g., Visual Basic, MS Excel etc),  you want to develop your software in.
b. Detailed procedure of doing manually, whatever you want your software to do.
c. All the data and information, you want to include in your software, for making various decisions and outputs.
d. Preparation of a detailed flow chart, based on which the software will be performing various tasks, and making decisions & outputs keeping in view the data input and user response.
2. In case you have (or can manage to acquire & collect) necessary skills & information mentioned above (regarding your proposed topic), you will need to the get the consent / approval of your teacher (and or department) to proceed with your proposed FYP.
I think this is not a great idea.
Do it only if you are motivated and you seek a graduate education specializing in Masonry. In that case, this project can be a huge milestone in your career.
Also, everything that you need to know about seismic retrofitting of masonry can be found at : http://www.world-housing.net/
You may also want to read a similar discussion here
My suggestions are as under:
1. Some research has already been done and more is being carried out on various aspects of beam-column joints, both nationally as well as internationally. Searching the internet for the research papers on beam-column joints, might give you some new idea to include in your FYP.
2. You may propose the use of fiber reinforced polymers (FRP) composites for retrofit purpose in your FYP. Although very efficient for seismic retrofit, these are costly materials. Since these are imported materials. Therefore, you will have to check their availability locally, before proposing their use in your project.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
