Dear all,
1. Do we need to scale Time History Records for Linear analysis? Like we do in RSA?
2. How can we model a damper staying in linear analysis domain? as I am working a tall building for which I am not interested to go Non-Linear domain as this is part of my masters dissertation.
I am studying about controlling building motions in long-period ground motions. These dampers are different than normal dampers because in long-period ground motion sway is much much more than in normal conditions. I just need the equivalent approximate increased damping ratios for these specialized dampers to use in linear time history analysis for all the modes. I need to cite this in my dissertation preferably from a book, from a manufacturer or from an expert.
Thats an interesting document although I already read it :) but I think I am not gonna scale the records as I am not studying or doing a comparison between code based equivalent static and actual time history records. Neither I am designing the structure for seismic forces. I am studying the effects of long-period components in time history records on tall buildings. So I should be concerned with that.
But about the damping ratio, yes I have written the company in second link you mentioned above (First one is not working). Still I have not got a reply from any firm/expert about this. I just need a recommended rough "FEEL" value that can be used for my study.
You can google Taylor Devices to get the working link: http://www.taylordevices.com/
They really helped me and I have included their recommendations in analysis and acknowledged it properly by attaching our correspondence with thesis. They suggested 7 to 10% damping for seismic and about 4% for wind. Although any value can be achieved but might not be practical.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
