Seismic Frame Check
R.Gorsi
W.Salaam,
For Dual Systems, frames of dual system are required to resist at-least 25% of the total base shear. This ensures that system has sufficient redundancy to justify the higher R value associated/ used with Dual Systems.
There are different way to do it. You can make a copy of your model (or do save as; whichever is more convenient). Assign stiffness modifiers to walls so that they would be taking gravity load only and analyse your model for 25% of total base shear. They other way would be to remove wall panels and just leave the boundary elements and analyse your model.
  • 4 years later...
Dear Sir,
Could you please advise which modification factor should be modified so that the wall only take gravity load.
I have tried f11, f22, f12, 311, m22, m12 to be 0.1 but the wall still take the most of base shear.
In addition, for the 2nd way, if removing the shear wall, how is the support of the moment frame (beam) at the connection with the shear wall? Case 1: beam is fixed to shear wall. Case 2: Beam is pinned to shear wall.
Thank you.
That is strange. You can try a lower value like 0.001.
If you remove the wall, you can model dummy columns to replace the shear wall. The connection of beam can stay as it is.
I'll do the following to make sure beam/columns of dual frame can resist atleast 25% of base shear.
Find out the %age base shear resisted by column In the original model.
Determine the magnitude of base shear that the column should be able to resist, lets say 'x' units based on 25% requirement.
Save the original model with another name for design of beam/column only.
Increase scale factor of EQ untill the sum of shear force due to EQ of columns at base is equal to x. Design beam columns for relevant load combinations for this magnitude of EQ.
Go back to original model and update beam/column design. Check the %age base shear resisted by column in the original model to make sure that columns doesn't start attracting shear force more than 25%. Otherwise revise the design again for higher forces.
