Retro Fitting Of Steel Stairway For Emergency Exit
shani2k2
After the earthquake of 26th october , our attention went to emergency  exit steel staircase which by no means can be termed as safe
plz see the attached report.
the main cols have been placed on earth without any foundation
steel members are under size
members are not straight .
can this be retrofitted ?
how?
waiting anxiously for a solution by so many good SE engineers lets see who has the knowledge to do it!!!!!!!!
ZeeshanASSESMENT REPORT OF EMERGENCY STAIR CASE OF BUILDINGsepak.docx
Here are my two cents:
Steel structures are comparatively easier to retrofit. However, you will have to determine
- the locations where you need strengthening,
- how much strengthening is required?
- how this can be done?
- whether it is economical (as compared to complete replacement)? , and
- will the structure, in retrofitted form, be visually acceptable?
This can be done by modelling the existing structure in ETABS or SAP2000 etc., using member section properties as per actual section sizes, and a suitable steel grade (using best and safe judgement, based on quality and physical condition observed at site). Apply all applicable code requirements  (as per IBC, AISC, ASCE etc,)  and observe stress levels of various members.
Now, after saving the model with a new name, upgrade all the failing members with larger or alternate member sizes (to which these can be replaced or upgraded by structural additions/modifications).
Comparing the results of the two structural models, mentioned above, will give you a clear idea about where the retrofitting is required, and to which extent.
In case (after the above analysis, and working out relative costs), it is determined that retrofitting will be economical (rather than complete replacement) and visually acceptable as well, it (retrofitting) may involve replacement of or additions/ modification to various existing members. Required connections may be made using welding or bolting, whichever is appropriate.
how?
Zeeshanattachicon.gifASSESMENT REPORT OF EMERGENCY STAIR CASE OF BUILDINGsepak.docx
One of the worst Emergency Exits that I have seen. What company do you work for?
Major challenge with retrofit here is that the all members are significantly undersized and connections are not up to mark. Connection capacity is likely to be signifcantly low. There is also a question on the workmanship of Abid Welder. I would scrap it.
@AYESHA..
this was not constructed or design by us , its the work of  Abid Welder, and i have to make this so called stairs safe for use and approval is to be taken from the abid welder like metality
So whats the outcome from your company ? I don't see retrofitting viable here.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
