Query about progressive collapse and redundancy
Mahnoor Khawaja
i have read this line; i have understood the whole sentence and concepts of the terminologies used in it except continuity. can any one explain what's meant by this " structural continuity"?
The underlying principles involved with progressive collapse are redundancy, continuity and ductility.
A progressive collapse is a catastrophic partial or total structural failure that ensues from an event that causes local structural damage that cannot be absorbed by the inherent continuity and ductility of the structural system.
If i understood your question correctly then your above statement states that progressive collapse happens due to
1. lack of redundant elements
"A redundant or indeterminate structure has more structure than is absolutely necessary. "
2. lack of continuation
Simply supported beam vs 3 span beam. Which one has better moment redistribution?
3. lack of ductility
Shear wall system vs moment frame. Which one has better ductility.
Redundancy and continuity are interrelated. However, continuity might not be a good thing in certain cases. One example of that would be where you have T or L -Shaped building in high seismic zones. Continuity in such cases could result in significant torsion. The statement posted is a "sweeping statement" and interpretation varies across different cases. There is no right or wrong answer.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
