Selecting Nonsway Option For Zone 4 Buildings In Etabs
Nasir Malhi
Dear all, Salam...
I am designing one storey frame in seismic zone 4 (quetta) using ETABS v 9.7.2...building is a RCC bunker (105'X38') with adjacent office area (105'X50').. since RCC bunker has walls and slabs of thicknesses upto 4' and 8' thick... it becomes very stiff structure..how will frame structure for office adjacent to it will perform... guide me if I can take it as Non sway structure (office area) or not or I may design it by selecting SMRF option only in design preferences...kindly give me also literature/code reference for choosing SMRF/Nonsway criteria in zone 4 area of Pakistan....
if the structural system of office space is connected to shear-wall structural system of bunker, then gravity loads will control the design of the structure of office space. You can consult chapter 10 of ACI 318-11 to know if frames of office space are sway, or non-sway.
  • 5 weeks later...
Bunker has raft extending 5 ft out of its peripheral wall.expansion joint not possible..footing levels are much different upto 10 ft...slabs and beams of office block will rest on rcc bunker wall...kindly advise...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
