Modal Analysis - Torsional Mode
rummaan17
Dear All,
I received a peer review about the modal analysis I conducted in a high rise building. It states the following :
"The preliminary mass participation factors indicate that mode 1 is predominantly translational in the transversal Y direction, mode 2 torsional and mode 3 translational in the X direction. It is not ideal to have torsional as mode 2".
1. What is the effect of Mode-2 on design as we usually concerned with fundamental frequency.?
2. How torsional modifier in ETABS is going to affect in this case?
Any addition would be highly appreciated. Thanks in Advance.
Dear Mr.Rana,
Can you please comment on my modal mass participation factor acquired from ETABS, what you can analyze seeing this results
I am still confused about modes to be well separated. I have 15 storey building. I find my modes to be separated.
  • 4 months later...
Dear Rumann,
Based on the image you have attached, and as you have asked me to comment, please read below;
In mode 1, 2 and 3, I see almost equal mass participation in all three modes
Mode 1 is translational in Y direction with 60% mass (T=2.7s) Rz=1%
Mode 3 is translation in X direction with 58% mass (T=1.7s) Rz=1%
Mode 2 is torsional mode around Z with 61% mass (T=1.9s) Ux=Uy=1%
Your building seem to be more rigid (more stiffer) in X direction (check framing) than Y direction.
The building does not seem to have torsional irregularity (~CR=CM).
The building is regular vertically and does not seem to have higher modes effects. This is because I do not see coupling between rotation and translation in any mode. See above, mode 1 & 3 have no torsion (1%) and mode 2 has no translation (1%). That implies the building is regular.
12 hours ago, rummaan17 said:
Dear UmarMakhzumi,
What other columns are you looking for let me know. I have incorporated Translation and rotation in all three directions.
Dear rummaan17,
What you have attached is fine too. I had a different version of SAP and I am used to a different view that shows total percentage.
