failure of beams in etabs
Engr Fayaz Ahmad
hi ,
   I am designing a two storey mosque 40x80   the c/c spacing between grid is 13.33 ft..  and now matter how deep and wide beam I provide  it still fails in seismic design.. can any one help me out .. here is the model attached.
thanks
FIANL MODEL 4.EDB
I am unable to open your model in version 9.
Which ETABS version you are using?
If you could attach text input file (.$et) of you model, I may try to open it in ETABS9 to see what the problem might be.
Just now, engruzair said:
i am using etab 2013 version,  most of my beam are failing in torsion .  i increased the size of beam but it still show torsion failure ,, can i put the modifier to .001   i have read some where here
here is the file.. tnx
FIANL MODEL 4.$et
