RCC Dome Design
Sohaib Iqbal
Sohaib,
For basic theory & assumptions regarding dome design, you may consult following links, in addition to the books dealing with design of shell structures:
1. Reinforced Concrete Dome Design- RCC Dome Design.pdf
2. Design Principles and Analysis of Thin Concrete Shells, Domes and Folders
3. Design and Construction Criteria for Domes in Low-Cost Housing
4. Design of Circular Domes by PCA- design_of_circular_dome.pdf
Modelling of a dome in SAP2000 is illustrated in the following link:
http://www.play-it.pk/watch?v=fM8r9hc9QbQ
  On 3/26/2016 at 5:53 PM, engruzair said:
Sohaib,
You need to go through the links Uzair gave you to design the dome for reinforcement.
  • 3 years later...
  On 3/26/2016 at 5:53 PM, EngrUzair said:
Sohaib,
Uzair have you checked the design calculation of this article? If Dia is 12m then how come the radius 18.5m? please help. I need to learn this. image.png.ee9630287587a8ce4cdbc0245bd4d92c.pngimage.thumb.png.891432190264b84debbe2870b9ecf9fa.pngimage.png.5b02b61e35030f9ef36abd80f4f7a749.pngimage.thumb.png.6e99550c7a98017e63342aeda7b4fddf.png
Edited by Tufail Mabood
Spreadsheet preview
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
