India Kolkata flyover collapse: At least 18 dead
Quote
A flyover under construction in the eastern Indian city of Kolkata (Calcutta) has collapsed, killing at least 18 people and injuring others.
Many people are feared trapped under the concrete and steel bridge, which fell on a busy road.
Images show residents using their bare hands to help the rescue effort.
Safety issues such as lack of inspections and the use of substandard materials have plagued construction projects in the country.
The accident took place in an area near Girish Park, one of Kolkata's most densely populated neighbourhoods, with narrow lanes, and shops and houses built close together.
The 2km-long (1.2 mile) flyover has been under construction since 2009 and missed several deadlines for completion.
The causes of the disaster were not immediately clear but the company in charge of the construction, IVRCL, said it would cooperate with investigators.
More details here:
http://www.bbc.com/news/world-asia-india-35933452
According to a report:-
"6-7 hours before the failure, when concreting was half way, the bolts in cross girder of the steel girders placed on cantilever pier cap sheared off. This apparently happened because of excessive deflection of the pier cap, over which these longitudinal girders were placed. Apparently, instead of trying to find out the reasons behind this bolt failure, instruction was given by the site in-charge to weld the bracing again and go ahead with concreting."
but giving a look to the images of collapse bridge, it was quite a risk to go for such a design when we are aware of construction practices in south Asia ...there should be some alternative path for such cases  for load.
Kolkata_Flyover_Collapse.pdf
Here is an updated infographic that I came across today. Looks like failure occurred due to lateral torsional buckling. The girders compression flange lacked support.
Interestingly, this is the second failure I have seen within an year caused by lack of compression flange support. You can read about the other one below:
Quote
Three girders on the bridge over Groat Road buckled in March because the subcontractor hired to install them "misinterpreted" the bracing requirements in the engineering plans, the city says.
The subcontractor, hired by Graham Group, has 40 years experience in the field and is considered an industry leader, said Barry Belcourt, the city's branch manager of road design and construction.
The girders buckled at around 2:15 a.m. on March 16 while they were being installed on the 102nd Avenue bridge.
"There shouldn't be a lot of room for misinterpretation, but in the end that's what it was," Belcourt said. "The proper sequencing and the proper bracing at the right time wasn't followed to the 100th percentile, and therefore we had a failure."
Read more: http://www.cbc.ca/news/canada/edmonton/buckled-girders-over-groat-road-weren-t-properly-braced-1.3160105
This photograph from March shows the three twisted girders that caused all the problems. (Supplied)
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
