Manual vs ETABS
Kasim
 When i use Membrane for slab my Manual calculations matches with ETABS and when use Shell thin ETABS gives very small Moment As compared to manual, Can someone explain why,?
Membrane carry only in-plane stresses (f11,f22 & f12) while SHELL take both in-plane (f11,f22 & f12)  & out-of-plane stresses (M11,M22 & M12).
So in case of Membrane loads applied are totally transferred to the supporting beams whereas Shell have bending stiffness and therefore resist some portion of the loads by flexural deformation.
Modelling area element (slabs) as a shell element with the stiffness modifiers f11=f22=f12=m11=m22=m12=0.25 (according to ACI 318 Chapter 10) will be show more realistic results than that of modelling it as Membrane with modifiers f11=f22=f12=0.25.
Stiffness Modifiers are generally applied for considering cracked section analysis in our design, so it directly affect deflections.
Directly it is not affecting Moments BUT indirectly it is affecting the moments by moment redistribution.
A shell will transfer load to the 4 nodes into the supporting column/support. In order to get the same results as membrane, use 0.25 modifiers in "m" and also mesh it every meter so the shell is divided every meter and the supporting beam gets loaded as UDL every meter.
