Bending moment diagram in Sap2000
shahbaz
Can anyone tell me what effect happens in the bending moment diagram when you assign insertion point ‘’top center‘’ to a roof beam in sap2000 beam column frame model.
The default Insertion Point is always Top Center. If you're only working with gravity loads there should be no change in the end moments.
However if you provide an offset to both End-I and End-J in the dialog box AND uncheck the "Do not transform stiffness matrices" checkbox at the bottom, there will be an additional moment on the column below for gravity loads.
If there are lateral loads present, only then the moment on the column below (or any fixed support for that matter) will change to the magnitude of "force times beam depth/2".
ALWAYS remember to uncheck the "Do not transform stiffness matrices" checkbox if you want the program to consider the effect of insertion points.
