Steel Structural design for sandwich panel
Salman Khan
Hi
I am installing sandwich panel which is 19 feet x 35 feet.
Load of panel per beam would be 2 tons.
I am stuck with what size of Guarder should I use for beam bearing 2 tons on 35 feet. Some suggesting 8"x4", some suggesting 10"x5" and some suggesting use 8x4" with steel truss just below guarder.
Can someone help me on this? I am attaching basic diagram.
Salman Khan
Selection of the size of a steel beam depends upon the design moment to be resisted and the structural steel grade of the beam material. Knowing these two parameters & design requirements of the steel design code, you can calculate section modulus of the beam required to resist the applied moment safely. Any steel section (e.g., 8"x4", 10"x5", etc.) having a section modulus equal or more than the required section modulus should be Ok to use, provided it satisfies all other relevant design & serviceability requirements of the applicable design code as well.
In Pakistan, grade 36 steel is commonly available. Grade 50 steel might also be available.
  On 7/23/2016 at 10:23 AM, Salman Khan said:
Further would truss be better option than guarder?
This can be decided properly after designing the structure, and making a comparison of material and fabrication costs. However, designing a beam or girder is a lot easier & less time-consuming than that of a truss. Moreover, fabrication costs are generally higher for a truss. In addition, you will need a higher roof, in order to accommodate greater required depth of a truss, all other parameters being the same. A truss may be preferable in some cases e.g., when a beam section of required size is not readily available in the market. However, this situation might not be governing factor in your case.
Edited by engruzair
