hey
Yaseen H
Hey. I'm a final year civil engineering student from Nust. I have been checking this forum lately and i must say that this forum is very helpful for a university student. The problem i'm facing is that this forum does not appear in Tapatalk (android app) which makes it hard for me to visit this forum on my phone. I think the admin needs to register on tapatalk site or something to get the forum appear on the app. It would be very helpful if admin here does that.
welcome yaseen!!!admin will work on this if it will be feasible forum will be available at tapatalk. forum is available at facebook page "https://www.facebook.com/SEFP.Pakistan/?fref=ts" check if you can access it from your android.
Hi @Yaseen H,
Thanks for your feedback. We do have a mobile skin for the forum. The forum as a default displays that skin when you login through your cell/ smart phone.
Regarding Tapatalk, it might be a good option for the forum but right now our financial resources are more focused on growth and advertising. That is definitely something we will look into in near future.
Cheers!
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
