RCC Basement vs Pillar Foundation for Home
BilalAhmad
I need your help in deciding whether to go for a RCC basement or Pillar foundation for home construction. I am not a civil enginer. I want the home to be constructed on a strong foundation. I have heard from someone that basement makes the home weak in terms of its foundation. For example in earthquake home with a basement can be more vulnerable to cracks or collapse. I have zero knowledge about construction. That is why I need your help.
Should I go for a RCC basement OR pillars foundation.
My only concern is that the home should be on a strong foundation. I am planning for ground floor and in future if needed then first floor. Please guide me which way to go.
The simplest answer would be both thins are possible with equal safety.It is only you who is to decide whether you need basement for extra space or not? because ultimately it is going to affect your cost of construction. Kindly tell in which city/area this house is going to be constructed. Also tell what type of terrain/ site grading is there. Some times providing basement may reduce your cost of backfill. So tell something about soil and site grading. Is it flat, slopy, hilly or what?
The added cost of constraction because of the basement is not an issue. I can afford to go for it but again my concern is the saftey. Specially in earthquake. Site grading is also not an issue because only 3 feet grading is required. The surfuce is plain and does not require more than 3 to 4 feet backfill. The water level is 60 feet in the area I am planning to build the house.
It is on the main G.T Road of the Peshawar Noshehra near New City Home Residintial Housing.
If In case I decide for the basement, does only the exterior walls has to be RCC OR the inner walls also need to be RCC?
Only exterior walls need to be of RCC. For construction purpose, U can consult the following manual. and MUST follow its practices. But remember, it is not the design manual. So you need to have a good design of your house including footings, RCC walls, band beams, and corner columns etc.
I remember Nowshera has some flood history too so you might want to reconsider the basement portion based on that.
However, if you still wan to to have a basement, a semi-basement, just 4' below grade might be more in-expensive option. You can also ask your structural engineer to design a masonry retaining wall (if he can). That can save you some money. Also, things to watch out are water proofing details at the exterior face of the wall.
Adding a basement for home construction is obviously the owner's choice. But as a structural engineer for home construction in Pakistan, I would highly recommend not to add basement. This is due to lot of additional expenses, like RCC retaining walls, waterproofing, flood control, toilet/bath expenses, ventilation etc.
If designed and constructed properly you do not need to worry about earthquake. Again, I would have added one and half additional floors from the same money being spent on basement and also forget about the worries mentioned above. Or could have spent it elsewhere like finishes, elevations etc.
And what do you mean by Pillar foundation?
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
