Design life of RC structures
EngrUzair
AA!
Dear Engineers,
1. What is the design life of an RC structure according to various international codes? Please refer to specific section of the code, if possible.
2.. What about design life of RC structures, being designed & constructed as per present practice in Pakistan? Is it mentioned somewhere? In it is not specified, then whether it should be same as recommended in international codes, or.........?
Please discuss & give your recommendations as well.
Not sure about Pakistan building code, but this might be of your interest;
http://www.concrete.org.uk/fingertips-nuggets.asp?cmd=display&id=750
Or in ACI 365.1R
http://civilwares.free.fr/ACI/MCP04/3651r_00.pdf
  Quote
2.3.1 Background on code development—While AASHTO (1991) specifies a 75-year design life for highway bridges, ACI 318 makes no specific life-span requirements. Other codes, such as Eurocode, are based on a design life of 50 years, but not all environmental exposures are considered. ACI 318 addresses serviceability through strength requirements and limitations on service load conditions. Examples of service load limitations include midspan deflections of flexural members, allowable crack widths, and maximum service level stresses in prestressed concrete.
Or in terms of sustainability as per BRE (Building Research Establishment) or BREEAM program
http://www.gov.scot/resource/doc/217736/0091011.pdf
  Quote
By dividing the building into structural and non-structural elements, their lifetime may be more easily estimated. Structural walls may be made up of masonry, steel or timber frame whose durability and lifetime in most cases would be a minimum of sixty years.
Also see this
http://www.structuremag.org/?p=9459
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.193.1783&rep=rep1&type=pdf
I don't have a reference from Canadian Building Code, but I have seen a design life of 50 years in client specifications. Also, to me this is what is the basis is in design clauses (like Maximum Considered Earthquake is based on 2% probability of being exceeded in 50 years, or wind/ snow design loads are based on 50 year cycle).
For Pakistan, it should be same as international code.
In Canada, even though design life is specified in the documents, I have seen engineers continue to retrofit or modify existing structures which have passed the 50 years mark as long as field tests done to see the condition of concrete/ steel come acceptable. We have got a bridge in Edmonton that was built in 1915. It has been retrofitted and continues to serve the community.
  • 10 months later...
@UmarMakhzumi just want to add one cent, in gulf region, some companies are also focusing on IGCC for sustainable and Green building concept, when client inquire about the Life span of building, specially Architects refer to IGCC(International Green Construction Code).
@UmarMakhzumi..The base line of this code is "International Energy Conservation Code", so does the primary objective of this code is effective conservation of energy in buildings and promote green construction environment rather than structural design. it was supported by ASTM and ICC.
Wherever seismic design is concerned it directs to International building Code ( IBC ), so no change in probability of seismic activity.
In one of my project client asked about the building span/life, so we recommended him 50 years based on what you asked and past experience, however architect recommended 60 years.
Thanx
I believe these values can be interpolated for a different probability. I know a tool for Canadian Seismic Values that does that. Anyway, I think if design life is 60, then the values should be used for 60. It would be interesting to know if someone has done this kind of interpolation and is willing to share info here.
