Applying triangular load on plates/shells in ETABS or SAP200
groszni awesome
2 hours ago, groszni awesome said:
Assalamualaikum SE Pakistan, im about to design a retaining wall and would like to know is there any option/ is it possible to apply a triangular load on shells/paltes/membrane? or im just gonna model it as a 2D thing?
regards
You can do like this;
What you have to do is to note down the z coordinate of each shell element along the height (in Excel e.g.) and calculate the force at top and bottom node of each element, then apply the average pressure in local axis 3 (plus or minus).
Tip: Always model retaining walls/swimming pool etc so that all the walls have local 3 axis either inside the pool/container or outside. So you can select all the walls once and apply the pressure in one go. And for that turn on 3d view in XZ or YZ in ETABS and select top most mesh, apply pressure and so on. Its not that difficult.
To calculate average pressure you can either make your own excel sheet or use the following I once made.
Water Pressure on Walls in ETABS.xlsx
On 2/19/2017 at 7:49 AM, Saad Pervez said:
Sir @Rana, can we use dummy lines? A dummy line can be drawn replicated every unit length and tributary triangular load applied to that line.
Yes or by any other mean like manually applying the joint loads.
I always follow the same method but while reporting of forces by etabs, it reports excessively high shell stresses near corners and joints? How to overcome this issue to get realistic value? What i did in last project i neglected the value of stress of bottom most plates near joints upto a distance equal to half thickness of the bottom slab. But i still doubt the value because it use to b higher than the manual calculations.
That is a common FEA problem. You get infinite stress at supports due to infinite stiffness.This is a problem of stress concentration. For commercial design purposes what you did is okay.
  • 8 months later...
 I have tried by assigning non uniform load on the wall in etab and I faced problem of finding value of (A,B,C,D )but later I have prepare a sheet excel to find (A,B,C,D ) from some input value shown in high lighted blue I will try to attach the excel sheet here and it is use full only for lateral water forces for tank or swimming polls and I will try to prepare additional sheet for other type
WATER FORCE ON WALL.xlsx
triangular load can be provided by assigning non-uniform shell load via equation as described in etabs documentation. My issue is how do I find the reinforcement for the out of plane forces in retaining wall or basement wall. I think what etabs gives is the reinforcement for the in-plane forces assuming it a shear wall by default. But retaining wall or basement walls are different animals. they are simply a cantilever slab or a two way or a one-way slab just placed vertically. how do I design a vertical slab? or get etabs to treat wall as a slab rather than shear wall?
Edited by Beenay Beenay
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
