Beams and Column failed section help
SEs United
Aslam o alikum every one,
Dear seniors i am new to Etabs and i was designing a multi story plaza my beams and column failed i tried to revise the design by applying the bigger sections but still they don't satisfy
These are the error i find in summery of designed section
1. For beams it says the shear stress due to shear force and torsion together exceeds maximum allowed
2. For columns it says reinforcing required exceeds the maximum allowed
How can i revise the design and satisfy my sections.  Kindly help me in it because increasing member size is not helping
i am attaching my etabs project for your reference thank you.
Plaza Design.rar
Edited by SEs United
I haven't checked your model but here are a number of things to consider.
1. For 1, you can set torsional modifiers zero where you anticipate compatibility torsion. Check the link below:
2. You might want to check your applied load units as well as load combinations. Either, the error is correct or applied load, load combination or section size is incorrect.
Thank alot for your response.
well it i had made this model on Etabs 16 and i made same model on Etabs 9.7.4 and it turns out that things are working well in older version dont know why. i mean if i increase sections they are satisfying now on the older version of Etabs. .
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
