Beams and Column failed section help
SEs United
Aslam o alikum every one,
Dear seniors i am new to Etabs and i was designing a multi story plaza my beams and column failed i tried to revise the design by applying the bigger sections but still they don't satisfy
These are the error i find in summery of designed section
1. For beams it says the shear stress due to shear force and torsion together exceeds maximum allowed
2. For columns it says reinforcing required exceeds the maximum allowed
How can i revise the design and satisfy my sections.  Kindly help me in it because increasing member size is not helping
i am attaching my etabs project for your reference thank you.
Plaza Design.rar
Edited by SEs United
I haven't checked your model but here are a number of things to consider.
1. For 1, you can set torsional modifiers zero where you anticipate compatibility torsion. Check the link below:
2. You might want to check your applied load units as well as load combinations. Either, the error is correct or applied load, load combination or section size is incorrect.
Thank alot for your response.
well it i had made this model on Etabs 16 and i made same model on Etabs 9.7.4 and it turns out that things are working well in older version dont know why. i mean if i increase sections they are satisfying now on the older version of Etabs. .
