Unable to print summary report in ETABS
ShamiqSaeed
Assalam U Alaikum everybody.
Im trying to display the summary report for my model in ETABS 9.7.4 but its giving the error "printing error occured", I printed summary reports of the same model this morning only but its giving this error now, i thought i had made some blunders in the settings so i reverted back to the source file as it was in the morning but its giving the same error, other models reports are being printed. Help would be appreciated
1. Import the original text file again.
2. If it doesnt work, assuming you have lateral loads, goto Tables > and show reactions for Ex, Ey ..etc...once the reactions are tabulated. Close and then try again printing the summary report from File menu.
The problem was with it printing the reactions and tabulating eccentricity ratios and drift ratios etc within the text file. It would create the text file till T calculations but the rest of the data would be missing after it gave the "printing error occured" dialog.
The only change I was making to the file was that I was changing the stiffness modifiers for the basement retaining wall from 0.01 to 0.0001, except f22 which was left as 0.1. Other than that, I did not change the meshing or anything else. What I dont understand is that how can that cause a problem in it printing the summary report
That shouldn't cause any problem. Try uninstalling and reinstalling ETABS.
That might have caused some inconsistencies in the calculations (very small/large values) and could have caused this error. There is not much diff in behaviour if you change from 0.01 to 0.0001 so keep the previous value.
That would not solve the problem i reckon.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
