Unable to print summary report in ETABS
ShamiqSaeed
Assalam U Alaikum everybody.
Im trying to display the summary report for my model in ETABS 9.7.4 but its giving the error "printing error occured", I printed summary reports of the same model this morning only but its giving this error now, i thought i had made some blunders in the settings so i reverted back to the source file as it was in the morning but its giving the same error, other models reports are being printed. Help would be appreciated
1. Import the original text file again.
2. If it doesnt work, assuming you have lateral loads, goto Tables > and show reactions for Ex, Ey ..etc...once the reactions are tabulated. Close and then try again printing the summary report from File menu.
The problem was with it printing the reactions and tabulating eccentricity ratios and drift ratios etc within the text file. It would create the text file till T calculations but the rest of the data would be missing after it gave the "printing error occured" dialog.
The only change I was making to the file was that I was changing the stiffness modifiers for the basement retaining wall from 0.01 to 0.0001, except f22 which was left as 0.1. Other than that, I did not change the meshing or anything else. What I dont understand is that how can that cause a problem in it printing the summary report
That shouldn't cause any problem. Try uninstalling and reinstalling ETABS.
That might have caused some inconsistencies in the calculations (very small/large values) and could have caused this error. There is not much diff in behaviour if you change from 0.01 to 0.0001 so keep the previous value.
That would not solve the problem i reckon.
