Fragility Curve
Fatima Khalid
How to read seismic fragility curves?  I have attached a picture of a fragility curve taken from internet. Assume it is for low-rise buildings, so what does it show?
Example: If an earthquake of 0.6PGA occurs, then there is a probability 25% building will experience extensive damage (h=7.5m), 55% will experience moderate damage and 90% building will experience slight damage. Am I right?
Does it mean that if there are 100 buildings, then it means that 25 building will damage extensively, 55 buildings will have moderate damage and 90 buildings will experience slight damage. But 25+55+90 is not equals to 100.
Please explain how to read fragility curve?
Thankyou
Here are my two cents:
1. A Fragility Curve (FC), like the one shown above, correlates 'probability' of occurrence of a well-defined 'damage state' or condition, in case a 'structure' is subjected to a given earthquake parameter.
2. In case of given FC, the 'damage state' is the Permanent Vertical Ground Displacement (PVGD), sustained by the 'structure' (which are actually two retaining walls (RWs), one 6.0 m & the other 7.5 m high), as a result of being subjected to various Peak Ground Accelerations (PGA) shown along horizontal axis of the curve. The 'probability' is shown along vertical axis. It is for a specific soil profile type C.
3. Various 'damage states' applicable to this FC are, as under:
a. 'Minor' means a PVGD value between 0.02 and 0.08.
b. 'Moderate' means a PVGD value between 0.08 and 0.22, whereas
c. 'Extensive/complete' means a PVGD value between 0.22 and 0.58.
4. This FC is comparing the probability of sustaining (or exceeding) the PVGD of the two RWs, when subjected to a given PGA. Continuous lines in the FC are for 7.5 m high RW, & dashed-lines for the 6.0 m high RW.
5. Now, if we want to know 'What is the probability of occurring 'Extensive/complete' damage (i.e., PVGD value of the two RWs at 0.6 PGA?', it is lesser for 6.0 m wall, and more for 7.5 m wall (Actual values may be read from the two lowest Red curves).
6. No. It is is not that way. This actually means that there is 25% probability that building will experience extensive damage (h=7.5m), 55% probability that it will experience moderate damage and 90% probability that will experience slight damage only. These probabilities are however independent of each other, and AFAIK, these are not added together.
7. This FC is part of a research paper that may be consulted at the following link, in case a deeper insight on the subject is required:
https://www.researchgate.net/publication/257102194_Development_of_fragility_functions_for_geotechnical_constructions_Application_to_cantilever_retaining_walls
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
