Combined Torsion and Shear Beam failure in ETABS
Bhuvan Neupane
even though all the sections is right the beam keeps on failing . i changed the torsional coffiecient to 0.01 . removed the load but its of no use it keeps failing giving an error shear and torsional coffficient exceeds.i have attached the model .
thank you for the help
SHIVA KUMARI.EDB
Edited by UmarMakhzumi
Edited topic title to make it more relevant to the asked question.
Dear Bhuvan,
Instead of overtly throwing your models at us, you could have explained the problem in more detail may be with some snapshots. We all are working in different places, and you could imagine it is not always possible to open some third party models/files/work during working hours.
Please try searching the forum for the similar questions and try to limit the problem with your own research and searching skills utilizing the past posts in this forum. If still you do not get the answer, please try uploading a snapshot or two of a specific beam in your model explaining your concern.
