Backfill load with backfill in negative slope
Waqas Haider
Assalam o alaikum,
If a retaining wall is retaining horizontal backfill, It will experience soil presure due to full height of backfill because we are forcing soil to retain at an angle larger than its angle of repose and hence failure wedge will cause force on full height.
But if a retaining wall is retaining backfill having sloppy face( for insulation purposes lets say), then it should not experience the pressure due to full height in my opinion. Because soil is having slope on opposite side, (away from wall) and hence if a failure plan would occur, it will cause soil to slide away from wall, not towards wall. This is what i think. Pictures are also attached. In my case the wall height is 30 ft but it is retaining a backfill with slope. So i wonder if i should take load due to full 30ft height. I think i can take 25 ft height(or some other reduced value). Can any one guide me how to calculate backfill load due to such type of backfill? Thanks.
Edited by Waqas Haider
As per discussion with my senior in office, we have concluded that since soil slope angle is already lesser than angle of repose of soil, so soil will not slide to that slope. Wedge of soil will be exerting pressure on wall because at wall we are forcing soil to stand at larger angle than its angle of repose. So i was wrong than we should take lesser backfil load than total height. We should take ful height or at least the height of soil which cantilever heal is bearing.... This is what we think.. If we concluded wrong, kindly correct. thanks.
W/s Waqas,
What is the angle of the backfill with the horizontal? After I know that I might be in a better position to comment in detail but as a matter of general approach, since backfill pressure on the wall is applied considering soil as a fluid (Gamma*H), the lateral load due to backfill should stay the same as your maximum height stays the same. This is my opinion and if someone else had a different one,  I would love to hear that as well. The image below explains the same thing.
Also what is the utilization of this wall. I mean why are you making it. What land use would be for the area on the non-backfilled face of the wall?
You have mentioned that the wall is 30 feet high. Is the backfill slope lowest point 30 feet as well or it goes much further below? Depending on that, there might be an alternate sliding plane.Alternate Failure Plane.png
