Here in Nepal, Municipalities are demanding for the CAD file of the Building Design from the engineers when applying for building permit. Is it legal to ask for the CAD file from engineers by government offices or government engineers. Isn't it the intellectual property of the engineer who designed the building? And obviously, the government engineers are exploiting the CAD files from the actual designers.
Do other countries also require the building designer to submit CAD files of their Design to Municipality offices or municipality engineers?
  • Waqar Saleem changed the title to Soft Copy of CAD files
but only way I found to make an autocad file read only is by selecting the file and then right clicking and then going to properties and tick marking the box that says read only.
you can still open this file but cant modify the drawing at first. But you can click on save as and save the file with another name and modify the drawing.
Is there any other way to make it read only- I mean a proper read only.
I think saving it as dfx file makes it read only. But question is- will municipality accept the dfx file instead of dwg file?
If they say- " dfx file is not enough. You should submit dwg file." Can I protest. Is it legal for them to ask for dwg file.
In Canada, same is the case. The notaries have even gone digital. Most professional engineers digitally stamp their drawings and pass it to construction which can print it to the required sizes thus minimizing paper copies. All submissions to jurisdiction are electronic versions as well.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
