Flexural Analysis
Eko Juwanto
Good evening,
here I have a double reinforced element (slab or beam) if I put the As equal to As', whether the concrete compressive force are neglected or have another for formula in case of A Tension equal to As compression
Mn = (As-As')Fy(d-a/2) + As'.Fy (d-d')
since As = As', its only left As' Fy (d-d')
the concrete is to be ignored?
  On 10/8/2017 at 5:08 PM, Eko Juwanto said:
Good evening,
doesnt work like that, you gotta check the compression steels strain (ecs) , it usually dont yield so you couldnt use fy
  On 10/17/2017 at 12:54 AM, Eko Juwanto said:
for simply work purpose, in slab reinforcement we usually put top rebar same as bottom rebar
You should not use that.because your design become uneconomical.so,you have to use As' if the section is double renforced section, otherwise for single reinforced section provide As' equal to Asmin and also even for double reinforced section As' shall be less than As, because As' is required to avoid exceding of neutral axis from ductility failure limit.
