Difference between Etabs 9.6 vs Etabs2015
Alhamdu Abdella
Hi, everybody befor i goes to my question i would like to express my great respect to all group members specially the founders.
My question is  i have  designend a mixed use building using Etabs version 9.6 the reinforcement results have seen exactly with out any overstress and axial compressive ratio warning, but when i was checked it on Etabs 2015 almost all the columns and beams becam over stressed and compressive ratio exceed warning measseg, pleace can you help me why and what new design consideration was added in the latest Etabs.
Thank you in advance.
7 hours ago, EngrUzair said:
Many major changes & enhancements have been made in ETABS between versions 9.6 and 2015. Details of these enhancements are given in following links:-
1. ETABS 2013 Release Notes v1300.pdf
2. Latest etabs release notes
Shukren EngrUzair for your interesting help.
But I need more explaination about that exaggerated difference on output result and which design parameters and limiting ratios create that difference.pleace help me I am highly confuised so I was restricted to use Etabs 2015 because it asked me large column and beam section relative to lower version. In short why Etabs 2015 limit the compressive ratio(Ned/Ac*Fcd..) to around 55 percent (in my opinion this creat all that difference), if this is the case, how can i able to edit that ratio limit, if i am wrong what is the case.?????
Thankyou for your serious consideration in advance!
First, be sure of the units. Second, there is no difference between two. ETABS 13 and onwards, they increased the non linear capabilities so it 'wont effect most of the users' as they say in their manuals. You can refer to release notes to find the new enhancements/changes.
Also make sure, the design code, reduction factors and load combinations you are using in newer version are right.
After I have designed using Etabs v9.6 I only opend on Etabs v2015 with out any change made and then I have choose the design code which similar to the previous one and also the combination is similar.but still overstress warning have seen.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
