Plinth Beam
Shahzad Khan
Assalamoalaikum to all members!
fisrt of all my apologies for any sort of mistake, this is my first post in this form.
i am currently working as a site engineer at a consultant, working for C & W Pak. the project, my consultant doing is, the Modeling of the Earth quick effected College located at Gul Abad, Dir lower. the zone is 3. the soil is sandy soil having boulders at the depth of 8 feet below. what kind of soil it is? i have noticed that the ties spacing  all over the height of the columns according to structure engineer  is 2.5" c/c. isn't it very low spacing. according to ACI 318-05 what should be the minimum spacing between the ties? the longitudinal reinforcement in the columns are 8 #6 bars. (i am fresh civil engineer having no experience on site).
WA.
Spacing of ties for RC columns located in earthquake zone 3 & 4 is governed by Section 21.4.4.2 of ACI 318-05, and other related sections.
You may check the required minimum & maximum tie spacing yourself, using the structural information (columns dimensions and bar diameters) for the columns used in the building under consideration.
Are these columns  circular or rectangle.
If these are circular then spacing of spiral looks OK. If rectangular, check ACI
Soil on these areas normally hard to soft rock categories, which have good bearing capacity.
Please keep in mind that all joints should be detailed properly. And casting should be inspected thoroughly
All of the columns are Rectangulars.
8 hours ago, EngrUzair said:
WA.
JazkakAllah Khair.
Guys your coop regarding implementation of the theoretical knowledge in field will be highly appreciated.
Can't say. It depends on design, if it is required, it is required. Some times site people are not happy to see such numbers from a design engineer. It is a good observation but you need to consult the design engineer for further guidance.
