Wind Tunnel Data In Etabs
WR1
Wind Tunnel Loading Data
Wind tunnel data is huge and tedious to input in ETABS or structural softwares. This data is produced from the wind engineering team’s softwares and usually provided in excel format. Usually if the building not regular, number of load cases are more than 20.
How to import all that data into ETABS model is still a big issue because ETABS only lets you export the data to excel. There is no import facility from any database or excel sheet. Unlike SAFE and SAP, ETABS does not offer the facility to use interactive database editing.
Well, I encountered this problem in my recent project, and then atlast I was able to import this bulk of numbers successfully in ETABS by using excel and VBA. Although I wrote the code for the format of data presented to me by the wind engineering team but it can be quite easily modified to satisfy other formats. Alternatively the wind tunnel data can be reformatted to match with the format, the coding accepts.
If someone out of you has faced a similar problem and is unable to execute it, you can contact me personally. May be I upload the sheet soon here but for sure not now.
  • 8 months later...
I will appreciate if you can impart your knpwledge of applying wind tunnel data loading in ETABS. We are designing a 34 story building in karachi where wind tunnel test is being carried out.
There is Atkins Etabs guide that has information on importing such data into Etabs.
You can download it from this thread.
  • 2 years later...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
