Slab deflection in ETABS
Omar Khalid
Hello,
While I was modeling a 20 story building with symmetrical concrete slab sections and loads in each story, I noticed that the deflection of the slab increases the more I go higher in elevations despite having the same sections, dimensions and loads.
I know that floors with symmetrical shapes and loads must endure the same stresses so it has the same reinforcement.
Can someone explain this behavior or explains why it occurs if I was wrong ?
Thanks in advance
Regardless the combination I choose to look for settlements. it's always increasing the higher I go. I've seen people modeling on youtube having the same problem except they don't talk about it like it's a normal thing. does it have anything related to vertical settlements of columns and walls ?
You can try it by yourself on etabs to check I'm right or not.
You shouldn't have it. If you want to investigate it please provide what combinations are governing.
Here is what you should do:
1) Do a gravity only analysis use load factor of 1 to see what results you are getting.
2) Do a lateral only analysis to see what results you are getting without any gravity load.
3) Compare results and check model for errors.
Just because other people are getting the same problem, doesn't mean the problem is there. We need to define a basis. I don''t use ETABS so I can't do checks on my own. If you want my input, please provide the results as requested above.
1) due to dead load only (own weight) the building tends to undergo a displacement in the x axis (horizontal displacement) the maximum displacement is 1 cm at the roof. Cause I have a stair wall with 2 elevator cores at one side of the building.
2) No earthquake or wind loads being applied yet. Only dead and live and slab deflections still increases when you go up.
3) No errors in my model.
35 minutes ago, miqureshi77 said:
this deflection shows in Etabs is global deflection, this will increase due to axial and lateral deformation of the members globally,
if you check deflection individuallly with respect to each floor value than u will find the same deflection
Can you tell me how to check it ?
That is due to unsymmetrical stiffness of vertical members. This however isn't the subject of our discussion.
Are you using any live load reduction factors? What is the difference in vertical deflection of the slab in 2 consecutive floors and what is the location of that maximum vertical deflection?
Edited by Ayesha
Maximum deflection in the first floor is 8.4 mm
2nd floor is 9.4 mm
3rd is 10.6 mm
4th is 11.65 mm
5th 12.6 mm
etc the 20th 20.5 mm
These are maximum deflections in each slab (same place) with dead load only (self weight only)
Omar, when you are reporting maximum deflections I assume that you mean maximum vertical deflections and it is relative not absolute. I still can't get my head around the fact that you have so much deflection difference even for gravity load case.
I will look further in this. I don't have an answer on top of my head. I also request other forum members to share there thoughts about this question.
Edited by Ayesha
If your model is correct, this increasing value of vertical displacement is due to the elastic shortening of the vertical supporting elements ( columns and cores). These elements are mainly loaded with compression stresses, which causes the reduction of its height and consequently, the increase of the slab deflection (vertical displacement).
No. It's maximum vertical displacement absolute not relative
If the building is regular as you said with same column sizes, axial shortening should be same provided loading and gemoetry all are same and symmetrical. Gravity deflection on same combination should be same at each level. And by deflection i mean z deflection not x.
That's what I was thinking, but the maximim reinforcement of a column at the base is 1.3-2 % which indicates which indicates small loads
I will try to screen shot it when I get home
 It's not entirely symmetrical I have 4 L shaped shear walls at the corners. Same thickness and nearly close lengths
the columns are symmetrical right and left sides with the same dimensions but not symmetrical in the Y axis
That's why I have a displacement of 1 cm at the roof in the y axis
but that shouldn't cause vertical displacement
note that the first floor has 8.4 mm vertical deflection while when I export the story to safe it gives me 2 mm deflection
Hey guys, I think I have found what's wrong but don't know how to fix it.
I drew the slab on SAFE and I have obtained the beams moments and slab deflections and they were very far away from ETABS results. However, there is an option to check it for columns and walls in SAFE it's called :
''Automatic rigid-zone area over column''  When I uncheck it, it gives nearly the exact deflection and beams moment in ETABS
This option means the following from CSI america's website :
''Rigid zones are used to model the physical overlap between columns/walls and slab, which prevents deformation of the slab at the column location. This also will have the effect of producing maximum design moments at face of columns/walls instead of center line of columns/walls.  This in turn will produce less reinforcement and hence a more economical design, and allowed by most codes(i.e ACI-318). Deformations also will be more realistic in this case.''
So I assume applying a rigid zone is more realistic but somehow it's not assigned in ETABS and I don't know how to assign it in ETABS.
What are your thoughts ?
Hey man, hold on. Your building isnt symmetrical. Also the theres difference between axial stiffness of cols vs walls. This will effect z direction deflections from bottom to top stories.
2nd thing..safe..in safe deflections will be different than in etabs. This has been discussed no of times here and you can search.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
